Display bezel - calling 3D printer users
Discussion about this major DATV Project. See also https://wiki.batc.tv/The_Portsdown_Transmitter
Postby g8gtz » Thu Jan 26, 2017 2:02 pm
The Hardware assembly guide https://wiki.batc.tv/Assembling_Portsdown is taking shape and we've realised it would be so much easier if we had a bezel assembly to mount the Touchscreen display.
We are not aware of one which is available from any suppliers - if you are, please post here - and wonder if anyone with 3D printer knowledge would like to design one and we'll put the files up on the wiki for everyone to use.
If there was sufficient demand, we could get some made and put in the shop.
M0GUR
Re: Display bezel - calling 3D printer users
Postby M0GUR » Mon Feb 06, 2017 3:24 pm
Hi Noel,
Depending on the type of build, this might work: http://www.thingiverse.com/thing:1920486
I have been playing over the weekend and run into a few problems. First up I had issues with my ADF4351 board, it is good advice to avoid the green version on eBay, I am convinced the board I bought has a fake chip!
Then I managed to get another signal source up and running, but couldn't recieve my own signal even across the bench. I eventually tracked this down to the Pi itself having strong emissions right about where I was transmitting in the 23cm band!
So my advice on construction would be to split the display and modulator boards away form the pi and screen each section as well as possible. I will be putting mine in a diecast box and fitting screening cans around each module. If I can get one of those "things" printed (shouldn't be a problem, there are 3 people with 3d printers close to me) I will put one on the outside of the box and run a ribbon cable through a narrow slot to the LCD.
Hope this is of help to someone.
Regards,
James M0GUR
Postby g8gtz » Tue Feb 07, 2017 8:21 am
Excellent - good advice on construction and thanks for the link James. I'm seeing someone at our local makerspace tonight who runs a small 3D printing company and will see if he can produce a few...
73 Noel
Wolfie G8VAT
Postby Wolfie G8VAT » Tue Feb 07, 2017 10:23 am
M0GUR wrote:Hi Noel,
Regards,
James M0GUR
Hi James
It certainly is of help and has clinched it for me.. I can now use the steel enclosure that I had otherwise tried (without success) to use for my mobile Analogue project..
Unless the BATC is planning on ordering a bulk print, I'll be looking into one after payday (yep still skint).
Many thanks, Gra.
Dah-di-dah
Graham G8VAT
G0DDX
Contact:
Postby G0DDX » Mon Dec 04, 2017 3:56 pm
Has anyone printed this out and used it?
I've just printed this one out, and the screen fits. However it looks a bit offset to me. The aperture could be more over to the Right as the left hand side of the screen is exposed, and the right hand side is covered by about 5mm of the case. Of course it will depend on how much of the screen space is actually used. I have not got that far. If anyone has tried this design, I would like to know if you found the same thing?
I don't seem to have mastered uploading Photos to show you what I mean. The instructions and "Add Image" button didn't work for me! (Using Chrome Browser).
Geff
G0DDX
De Geoff
G0DDX
Postby G8GKQ » Tue Dec 05, 2017 3:23 pm
Hi Geoff
The displayed image is offset on the screen area, so when you power up your screen, your housing should look correct. There is a dead area on the right hand side of the screen that is not sensitive to touch and has no pixels displayed.
To display images here you can simply drag then into the window that you are typing in from Windows explorer.
M0SKM
Contact:
Postby M0SKM » Tue Dec 05, 2017 8:56 pm
Hi Geoff
This is the very bezel; it's just fine.
Steve
M0YDH
Postby M0YDH » Wed Dec 06, 2017 7:33 pm
What isn't seen is the packing piece to make the screen stay in place. Mine is shown in pine on the Portsdown builders group
https://www.facebook.com/photo.php?fbid=1864987810184360&set=oa.133694017271267&type=3&theater&ifg=1
It's a fiddly bit of work and you electronics types might not have all the chisels and planes!!! ;)
The camera case for the HDMI lead Pi-Cam is also seen on the group pictures . https://www.facebook.com/photo.php?fbid=1865107690172372&set=gm.133732763934059&type=3&theater&ifg=1
It needs longer M2.5 screws to be bought as noted.
Both would make useful items in the shop that are tough to get.
David M0YDH
M0SKM
Contact:
Postby M0SKM » Thu Dec 07, 2017 12:13 am
M0YDH wrote:What isn't seen is the packing piece to make the screen stay in place. Mine is shown in pine on the Portsdown builders group
David M0YDH
Another option is to stick the display in with few dabs of hot melt glue. Mine has been in use since March and hasn't budged. Takes less than two minutes to fit; and not too difficult to remove if the need arises.
Steve
Who is online
Users browsing this forum: No registered users and 1 guest
