I am trying to drive an RA18H1213G brick amp from my digilite board. In FM service this amp runs sweetly at well over 20W out all day without getting too hot. Due to the low level output of the DigiLite some extra gain is required to drive the brick amp. I have tried a number of driver amps with the DigiLite including a VNA25 , SPF5043Z, and an ATF50189 (the MiniKits 1W amp) in various combinations. The VNA25 or SP5043Z both work well as a first stage but not enough drive for the brick amp. Adding the ATF50189 I get plenty of output and good linearity at 50mW or more. I have a switched attenuator in line to adjust drive. The problem is that when when I add the brick amp it all goes pear shaped. Spectral regrowth above about 2W out with visible signs of peak compression. In CQ-TV 235 a table shows optimum linear mode bias for this brick to be 4V with 0.9A quiescent current so I tried to stick to these settings. I have read here of others getting 10W out so what are they doing differently? Are they running a different bias? If so what level of quiescent current are others using on their RA18H1213G?
Any comment?
Dick G4BBH
